Critical PHP Vulnerabilities (CVE-2026-109618, CVE-2026-109619): What RunCloud Is Doing
PHP is scheduled to release fixes for two critical vulnerabilities today at 14:00 UTC. Both are rated CVSS 9.2. Both are reported to allow remote code execution without authentication on default PHP installs and as details leaked before the patch, exploits are already circulating.
What We’re Doing Now
We’ve disabled session.upload_progress on all servers as a temporary mitigation. Public research points to this feature as the attack path. It isn’t an official fix, but it closes the known route until patches land.
Adverse impacts of this: If your app uses PHP’s built-in upload progress tracking, progress bars may stop updating. Uploads still work. Most apps track progress in JavaScript and won’t notice.
Optional: Extra Protection with NGINX Templates
The attack needs a multipart/form-data request (the format used for file uploads). Blocking or limiting those requests at Nginx stops it before it reaches PHP.
We’ve released two Nginx config templates.
Please pick the one that fits your site:
Variant 1: Allow uploads on specific paths, block the rest. Multipart requests are only allowed on the paths you list, with a rate limit of 5 requests/minute. Edit the paths and limit to match your site before using it.
Variant 2: Block all multipart requests. For sites that never accept file uploads or multipart form submissions. Use as is.
You can find these templates here:
https://manage.runcloud.io/settings/nginx/templates/public
Before you pick Variant 2, check whether your site accepts uploads anywhere. WordPress uses multipart for media uploads, plugin/theme installs and many contact forms. If any of those apply, use Variant 1 and allow those paths (for WordPress, usually /wp-admin/async-upload.php, /wp-admin/update.php, /wp-admin/media-new.php, plus any form endpoints).
These templates apply to NGINX-based stacks only. They don’t apply to OpenLiteSpeed or LiteSpeed Enterprise.
How patches will roll out
Patches will be applied automatically to all supported PHP versions (8.2 and newer). You don’t need to do anything.
Timing depends on your stack:
- Native (NGINX / NGINX+Apache): We build our own PHP packages. We’ll build and release patched versions as soon as PHP publishes the fix.
- Docker / Containerized: These use Ondřej Surý’s PHP packages. We’ll release as soon as Ondřej publishes patched builds.
- OpenLiteSpeed / LiteSpeed Enterprise: These use LiteSpeed’s own PHP builds (lsphp). We’ll update as soon as the LiteSpeed team releases patched versions.
We’ll update this post as each stack is patched.
If you run PHP 8.1 or older
PHP 8.1 and older are end-of-life. PHP’s official fixes cover only 8.2 and newer. Assume your version will not get an official fix. RunCloud will not release patched builds for PHP 8.1 or older.
Switch your web apps to PHP 8.2 or newer before 14:00 UTC today. You can change the PHP version for each web app from the RunCloud dashboard.
Test your app after switching. Most modern WordPress and Laravel apps run fine on 8.2+. Older plugins or custom code may need updates.
The temporary mitigation stays active on older versions, but it’s not a replacement for upgrading. Don’t leave a site on end-of-life PHP once the details go public.
Recommended for Everyone
Be on PHP 8.2 or newer. That’s the only way to keep getting security fixes.
Updates
21 Oct, 8:00 UTC: Temporary mitigation applied to all servers.
21 Oct, 8:30 UTC: NGINX templates released.
21 Oct, 22:00 UTC: Patched builds released for Native and OpenLiteSpeed / LiteSpeed Enterprise. Rolling out automatically.
Native: patched build available
OpenLiteSpeed / LiteSpeed Enterprise: patched build available
Docker / Containerized: pending
If you have any questions, please reach out to support by opening a ticket in your dashboard as they’ll be able to provide the most specific guidance.
Maintenance mode has been lifted, so the RunCloud dashboard and API are back up. If any API requests failed while maintenance mode was active, please retry them now. Requests made during that window were rejected, not queued, so nothing will run on its own later.
Where the patches stand
We’re now testing the patched PHP builds before we apply them to your servers. A security patch that breaks a web application isn’t a fix, so we’re checking these builds carefully first rather than pushing them out untested.
Parts of the rollout still depend on third parties publishing their own patched builds, so we can’t give an exact time yet. Here’s where each stack is:
  • Native (NGINX / NGINX + Apache): patched builds in testing.
  • Docker / Containerized: waiting on patched builds from Ondřej Surý’s PHP packages.
  • OpenLiteSpeed / LiteSpeed Enterprise: waiting on patched lsphp builds from the LiteSpeed team.
Once testing passes, patches will be applied automatically to PHP 8.2 and newer. You don’t need to do anything.
In the meantime
  • The temporary mitigation (session.upload_progress disabled) stays active on all servers until the patches land.
  • If any of your web applications still run PHP 8.1 or older, now is a good time to switch them to PHP 8.2 or newer from the dashboard. Those versions won’t receive an official fix.
We’ll post here again as each stack is patched. Thank you for your patience while we get this done as smoothly as possible.
If you have any questions, please open a ticket in your dashboard or email [email protected] from the email associated with your account, and we’ll get back to you as soon as possible (as the support team will be able to see exactly which servers you have in your account and their server stack (Native, Containerized, etc.). Thank you.
Update: patched PHP builds are now available
The patched PHP builds for CVE-2026-109618 and CVE-2026-109619 are now published in the RunCloud package repository for these stacks:
  • Native (NGINX / NGINX + Apache): available.
  • OpenLiteSpeed / LiteSpeed Enterprise: available.
  • Docker / Containerized: not available yet. We’re still waiting on patched builds and will post here as soon as they’re out.
Patched builds roll out to your servers on PHP 8.2 and newer automatically, so you don’t need to do anything. The rollout isn’t instant, so if you want to apply the patch immediately, please keep reading:
Want the patch right now?
If you’d rather not wait for the automatic rollout, you can install it yourself on a Native, OpenLiteSpeed or LiteSpeed Enterprise server.
Connect to the server over SSH as root (or a user with sudo) and run:
apt update && apt upgrade -y
Warning: this upgrades every package on the server that has an update waiting, not only PHP. Services such as PHP-FPM and your web server restart during the upgrade, which can briefly interrupt your sites. Run it at a quiet time and make sure you have a recent backup first. If you’re not comfortable doing this, wait for the automatic rollout.
A separate update for containerized servers will follow.
About the dashboard today
The RunCloud dashboard and API were interrupted several times today while we pushed the patched builds out. Both are back up now.
Still in place
  • The temporary mitigation (session.upload_progress disabled) stays active on all servers.
  • If any of your web applications still run PHP 8.1 or older, switch them to PHP 8.2 or newer from the dashboard. Those versions won’t receive an official fix, and the patched builds above don’t cover them.
What’s next
We’ll follow up tomorrow with a detailed write-up of what happened today, including the dashboard interruptions. We’ll also post here as soon as patched builds for containerized servers are available.
Thank you for your patience. We know today has been disruptive, and we appreciate you bearing with us. We took preventative measures to ensure that both our and, by extension, your infrastructure were as protected as they could be.
If you have any questions, please open a ticket in your dashboard or email [email protected] from the email address associated with your account. The support team can see which servers you have and which stack each one runs, so they can give you the most specific answer.
Please share the URL of this detailed write-up. I could not find in anywhere. Thank you.
@teom This has now been published here: PHP2Shell (CVE-2026-109618 and CVE-2026-109619): What Happened and What We're Changing
Please check Patching PHP 5.6 to 8.1 for PHP2Shell on old Ubuntu servers by rebuilding RunCloud's PHP - DEV Community - I hope it can help some of you!
We have followdd the above instructions.
You state it is patched, but checking directly on the server (Ubuntu 18.04 Bionic), the newest build available from release.runcloud.io is still php83rc 8.3.17-1+ubuntu18.04+1. The official patched release is 8.3.36. apt-cache policy confirms 8.3.17 is both the installed and candidate version — there’s nothing newer in your repo for this distro to update to.
Could you confirm:
  1. When will 8.3.36 (or equivalent) be published to release.runcloud.io for Bionic?
  2. Is the “patched” status in the dashboard checking something else, or is this a display error?
This is a critical unauthenticated RCE, so an ETA would be appreciated.
Thanks,
Laurence
If PHP older than 8.2 won’t receive any updates or patches for this issue, how do I uninstall those versions from Runcloud OpenLiteSpeed so they don’t get used even by accident? Now it feels dangerous to even have them installed. Will Runcloud force them out at some point?
I have discovered a much easier to manage migration process… for PHP 8.x supported sites that is anyway.
I have old Ubuntu 18.04 servers which although has 8.2+ RunCloud have not patched it due to ELS (even though they did decide to patch 20.04 which is also ELS).
The biggest issue for migration for is DNS for me. I have many customers managing their own DNS and from experience its a nightmare to get some to update it. I even have customers who lost login to their domain registration and not bothering to get it! Its a nightmare.
This is why YEARS later I still have old servers for old sites including Wordpress as I cant change servers as I cant change DNS.
It was OK on Ubuntu 18.04 because it had PHP 8.3 so I can still run modern apps on it like Wordpress.
But now Runcloud wont patch it we habve no choice to move. BUT I found an easier way, with the help of Claude.
We create a new Ubuntu 26 server, set it all up and all that. Then in Runcloud clone an app to it, but then crucially we setup a PROXY on the server to get the website from the new server. So DNS still goes to the old server, but its serving the website on the new server.
We do this one at a time… we use Claude to access RunCloud API and it can do this on all sites autominously (although it does make mistakes to fix annoyingly, its not as smooth as it sounds).
Once all sites are moved and proxied, in Linode we swap IPs between old and new server. So all of a sudden the new server is the old IP, so ALL websites are now loading from the new server with no DNS changes. We have to use the RunCloud update IP to assign the new IP to it for RunCloud to use.
The one caveat which is not good is RunCloud does not have a swap IP feature. It wont allow you to add the new IP while the old server is in RunCloud still. There is absolutely no way I know you can keep them both in RunCloud, in case you wanted to keep the old server. You have to delete it from RunCloud, and hope they dont delete the server itself (they didnt for me, even though it said they would). So this is a huge caveat with RunCloud server migration process. They need to have a swap IP facility, or assign a temp IP to the old server.
So I moved two servers from Ubuntu 18.04 to 26.04 the past day or so. Went well. RunCloud could make it easier with the IP swap.
I also had issues connecting which broke cloning. Thats because we use CSF firewall and allow RunCloud IPs through it. BUT RunCloud added more IPs and did not inform anyone. I thought the breakage was them doing the work they did last week. Turned out my servers were blocking their new IPs. I have requested to RunCooud they inform everyone when they change/add IP addresses.
So the proxy then server IP swap works really well, and could work better if RunCloud support this. I had to use AI to setup the proxy as it over my head.
This is great thanks.
I do not think Wordpress should be left on old PHP, unless there is some huge bespoke plugin that would take forever to update, then Wordpress and its reputable plugins (which is what should be using if its 3rd party) should be easily updateable to the latest WP which works on PHP 8.2+. I dont think there is much excuse to not update Wordpress. So these sites should definately be moved to a newer server.
We have old Zencarts, Joomla, Craft, Expression Engines all on pre-one click update processes that just do not work on PHP 8, some not even PHP 7, so these are the problem CMSs! They cannot be moved.
Hi Team, I am still waiting for the Litespeed roll out.
Litespeed has been up for 4~5 days already.
Thank you for your continued hard work.
