RunCache is Now in Beta
Thanks Alex, I thought that might be the case! Well as I said before, I ideally don’t want to be installing it via the dashboard due to our tightly nit management of plugins via Composer and deployment pipelines. So if there will be an alternative download at some point in the future, then that would be great!
Hello
Installed runcache, problem is in preloader it says processing 600 url of 1920 urls but in dashboard it says only 20 pages cached and never updates
Also it could be very good if you could add optimization features like minification, lazy load, combine css/js and remove wc bloats and heartbeat control …
Hey @tachraweb :waving_hand:
Thank you for the note. Sorry to hear that this was your first experience with RunCache. Please open a support ticket for this, and our team will look into it/replicate it so they can push a fix for this edge case (apologies to direct this elsewhere, but it will be easier for them to provide support/investigate the specific web app/server setup/etc.).
These are great ideas and among the things we are considering. Thank you. :slight_smile:
