PHP2Shell (CVE-2026-109618 and CVE-2026-109619): What Happened and What We're Changing
On 21 October 2026, two critical PHP vulnerabilities, CVE-2026-109618 and CVE-2026-109619 (known as PHP2Shell), became public before PHP had released a fix. Both are rated CVSS 9.2 and allow remote code execution without authentication on default PHP installs.
We protected every server with a temporary mitigation before the official fix was out, and then rolled out patched PHP builds. But we also made mistakes along the way, and many of you felt them: the RunCloud dashboard and API went down without warning, patches reached some servers more slowly than they should have, and our updates didn’t give you the full picture.
This post explains what went wrong, where every type of server stands now, and what we’re changing so that the next vulnerability like this is handled better. We’re sorry for the disruption and the uncertainty it caused, and thank you for your patience.
Summary
  • Every server received a temporary mitigation on 21 October, before PHP released its official fix.
  • Patched builds for PHP 8.2, 8.3, 8.4, and 8.5 have been rolled out to native and containerized servers.
  • Containerized servers on PHP 7.4, 8.0, and 8.1 also received a backported fix.
  • Native servers on PHP 8.1 or older won’t receive a backported fix. If you’re in this group, see “If You Still Run PHP 8.1 or Older” below.
  • Servers on Ubuntu 18.04 can’t receive the patched builds. Ubuntu 18.04 and 20.04 are both end-of-life, so move to Ubuntu 22.04 or newer.
Where We Fell Short
We want to be clear about our mistakes first.
  • We took the dashboard and API offline without warning. To free up resources for building the patched PHP packages, we put the dashboard and API into maintenance mode without telling you first. For many of you, that unannounced downtime was more disruptive than the vulnerability itself, especially if you rely on our API. Once we added more capacity to the build process, it finished quickly. We should have done that first, and we should have told you before taking anything offline.
  • We didn’t keep you properly informed. Our updates were often written without the full picture, and some details changed as the situation developed.
  • We didn’t explain the containerized core well enough. It’s well suited to situations like this one, but we never made its advantages clear, so many of you didn’t know it was an option.
Why Some Servers Were Patched Faster Than Others
RunCloud manages more than 100,000 servers running over half a million web applications. How quickly a server received the fix depended on which kind of server it is.
Once the official fixes were available, we compiled the patched PHP builds within about 30 minutes. Two things took longer:
  • Getting the fixes. Hosting providers and server administrators around the world were downloading the same patched releases at the same time, and downloads from the official repositories were very slow.
  • Reaching every server. Rolling an update out to more than 100,000 servers takes time, and while our infrastructure was under heavy load, it took longer than usual.
Native servers
On native servers, we compile PHP ourselves. That’s how RunCloud started, when we needed PHP extensions and configurations that the standard builds couldn’t provide. Native servers receive every security update for supported PHP versions (8.2 and newer), but because PHP is built and rolled out as one set, updates take longer to reach every server, and backporting fixes to older PHP versions isn’t practical.
Containerized core
On a containerized server, each package runs in its own container, so we can update one package without touching the rest of the server. The containerized core uses Ondřej Surý’s PHP packages, which are widely used across the industry. That made two differences during this incident.
Containerized servers received the patched builds quickly, because updating PHP there means replacing one container image. And because Ondřej Surý’s packages include backported fixes for older PHP versions, containerized servers on PHP 7.4, 8.0, and 8.1 received the fix as well, even though those versions are end-of-life. We’re very grateful to Ondřej Surý for his work, which made this possible.
Where Things Stand Now
Server type
PHP 8.2 and newer
PHP 8.1 and older
Native (NGINX, NGINX + Apache)
Patched
No backported fix (see below)
Containerized core
Patched
Patched for PHP 7.4, 8.0, and 8.1
OpenLiteSpeed and LiteSpeed Enterprise
Updated as soon as the LiteSpeed team publishes its PHP builds
Depends on whether the LiteSpeed team backports the fix
Docker Stacks
Depends on the container image you deploy
Depends on whether the image provider backports the fix
  • OpenLiteSpeed and LiteSpeed Enterprise use the LiteSpeed team’s own PHP builds, which we pull from their official repository.
  • Docker Stacks get PHP from the container image you deploy. We recommend PHP 8.2 or newer, unless your image provider backports fixes to older versions.
  • Ubuntu 18.04 servers don’t receive patched PHP builds for any version. Ubuntu 18.04 and 20.04 are both end-of-life, so move to Ubuntu 22.04 or newer, ideally by creating a new server and moving your web applications to it.
  • The temporary mitigation stays active on every server.
Why We Aren’t Backporting the Fix on Native Servers
PHP 8.1 and older are end-of-life, and PHP’s official fixes only cover 8.2 and newer. Because we compile PHP ourselves for native servers, any change we make applies to every server we manage. Modifying the PHP builds that over half a million web applications depend on, to backport a fix, would risk breaking extensions and applications for everyone else, including the customers who asked for it.
Fewer than 10 customers have asked us for a native backport so far. Every one of those requests matters to us, and we don’t want anyone left without a safe way forward, so we’ve set out the options below, and our support team will help each of you choose and apply the right one.
The best long-term fix is to switch your web applications to PHP 8.2 or newer from the RunCloud dashboard, if your applications are compatible. Test each one after switching.
If you can’t upgrade yet, you have these options:
  1. Move those web applications to a containerized server. PHP 7.4, 8.0, and 8.1 have the backported fix there and stay supported. Our support team can help you with the move.
  2. Apply the mitigation from Patch Manager if your server didn’t receive it automatically. It protects against one of the two vulnerabilities, so it’s a partial fix only.
  3. Apply an NGINX template that blocks or limits multipart requests. This can break features that accept file uploads, such as media uploads and contact forms, so test your site afterwards.
  4. Put your site behind Cloudflare, so malicious requests can be filtered before they reach your server.
What We’re Changing
Vulnerabilities are being found and disclosed faster than ever, increasingly with the help of AI tools, and details sometimes become public before a fix exists, as happened here. We can’t control when that happens. What we can control is how ready your servers are, how quickly we protect them, and how clearly we keep you informed.
  • Protection before the fix. We deployed a temporary mitigation to every server before PHP released its official fix. We’ll keep doing this whenever a vulnerability becomes public before a patch exists. Servers that miss an automatic rollout can apply the mitigation themselves from Patch Manager.
  • Force updates are working again. The mechanism that pushes urgent updates to every native server at once had stopped working without reporting an error. It’s fixed.
  • No more unannounced downtime. If we ever need to take the dashboard or API offline during an incident, we’ll tell you beforehand.
  • Investing in the containerized core. We’re working on OpenLiteSpeed and LiteSpeed Enterprise support for it, and we’ll publish better documentation so you can decide whether it’s right for your servers. Native servers remain fully supported.
How we’ll communicate next time
  • Every update on our status page. We’ll post each update at status.runcloud.io as the incident develops, so there’s always one place to check where things stand.
  • Email when you need to know or act. We’ll email you when an incident affects your servers or the dashboard, and whenever there’s something you need to do.
If you have any questions about your servers, or you’d like help choosing the right option for older PHP versions, please contact our support team from your dashboard. We’re here to help.
Hi Raj thanks for the update.
I am running mostly on OLS, I noticed the changelog is Version 1.9.x – OpenLiteSpeed
I hope to see this implemented soon.
We are constantly in touch with LiteSpeed team and they have hinted us yesterday evening. Trying our best to push this by tomorrow if all tests are ok.
