If you’re using OpenLiteSpeed stack at #RunCloud ,
Some of your site(s) may be down already!
NET::ERR_CERT_AUTHORITY_INVALID
Subject: RunCloud Web Certificate
Issuer: RunCloud WebSSL Root CA
Ticket: 99003
SOLUTION
Clicking “Update” under SSL tab fixes the issues.
alex2
July 21, 2023, 8:08am
2
Yea same. Rebuild config app helped. Can someone tell me what happend?
brad
July 21, 2023, 9:55am
3
Where is this option?
I’m ok myself as I did the update and watched what apt was doing. Then rebuilt the server litespeed config.
austin
July 21, 2023, 10:34am
4
Thank you for sharing this.
Just submitted a ticket then came here to check because 90% of my websites were down when I woke up this morning.
Not how I wanted to start the day but at least it’s fixed now.
Select your application under ‘Web Applications’ → SSL/TLS → Update button on far bottom right of page.
brad
July 21, 2023, 8:14pm
7
Ok, that doesn’t apply/show if you use origin or custom certificates… only if you use autossl.
It’s all good, I was just looking for some clarification on where this option being spoken of was.
